I have noticed some issues with the front end of my 1932 Model B Roadster.
The most important issue is the state of my brakes. The levers sit vertical so I need to repair or even overhaul the brakes so the levers sit on an forward angle. That I can manage. The left brake lever/actuator however sits lower (picture 1) than the right one (picture 2) and because of that the bottom of the lever is almost worn through where it touches the shackle.
I cannot figure out what I can do to remedy this. Is my perch bent or otherwise wrong? I can also see that the bottom nut is not flush with the axle so the perch does not sit correctly in the axle (picture 3).
Besides the brakes there is more to do to this frontend that is not immediately clear from the pictures. The shackles need new bushes and the front spring is sagged so the bottom of the shackles almost rests on the front axle. All of the components need some cleaning to. Shock absorbers need an overhaul because of leakage so there is plenty of work ahead.
Does anyone have some advice on how to raise my left brake lever/actuator and did I overlook something else that is not right on my front axle?
Greetings, Dick Verboom from the Netherlands
