coachstaff
I inherited a 1931 deluxe roadster that I'm told has a factory installed model b engine. Could this be true?
Almost certainly not. But proof would be in the frame to engine numbering.
All Model A's of domestic production have a number on the frame top rail which is about under the driver's left foot as he drives. Covered by the body, a body removal is necessary to confirm this number.
The engines and frames were numbered the same from the factory on the assembly line. If yours is indeed a "factory B" then this would be the case.
Joe K
There are few "unmarked" Model A engines out there. I have one of them. (Its red and I'm assuming its an Allstate replacement from the 1950s.)Many a Model B engine has been stamped with a Model A or AA engine number by individuals that installed such an engine in their car or truck.
Why do you think it is a Model B engine? The Model B engine has a provision for a fuel pump on the right side. There was a high performance head for the Model A that had a letter "B" cast into it, is this what you are looking at? Photos are great.I inherited a 1931 deluxe roadster that I'm told has a factory installed model b engine. Could this be true?
So even a stamped number on the block/water inlet area matching your frame is unlikely to be THE number it had when it left the factory for a couple of reasons. And two numbers at the two locations might not agree.US (Rouge) Model B Engines
Model B 'engine' serial numbers started at 5,000,000 and increased sequentially. The assigned serial number was actually stamped on the (B-6395) flywheel housings of completed engines after they had passed run-in (run-off) tests and were released from the Engine Department for vehicle final assembly. The number pad above the block water inlet was left unstamped on US and Canadian built Model B engines.
The block/water inlet area is stamped with 72947
How did he determine it was produced in 1932? Was the serial number from an engine produced in '32? If it was a leftover sold in '32 it would have been titled as a '32 as defined by most DMV's at the time. If it was produced outside of the continental US they were a little slower on making the change over.A friend has a '31 widebed produced in and registered as a '32. It has an A engine.
