Model B engine water pump
k24556
The '29 Model A I am restoring has a 1932 Model B engine in it that is in good enough condition to warrant keeping it. I'm looking for an assembly diagram for the water pump so I can try to order some parts, mainly the seals and the grease cup. It is in prett good shape, other wise.
Thanks in advance.
The lead packing rings and grease cup should be the same as the Model A water pump.
Vince has parts for the B pumps as I recall.
A picture would be nice (close up from drivers side of pump) and might save you some problems down the line. In the meantime answer the questions in Post #5.
Charlie Stephens
