Bob Johnson
I am working on a Model B engine which has a huge rear main oil leak. The oil is leaking out the hole at the bottom of the flywheel housing where the cotter pin is located. It is not a drip .. drip. The oil is actually flowing out in an uninterrupted stream.
I have removed the horseshoe shaped inspection plate on the front of the flywheel housing. With a flashlight and mirror I found that the oil is coming out only at the rear of the rear main. There is no oil coming out at the front or sides (shims or bolts) of the rear main. With the engine running the oil flow out the back is so much that the oil squirts onto the front side of the flywheel. The spinning flywheel then throws the oil onto the sides of the flywheel housing and it then runs down and out the hole at the botton of the housing.
I have checked for excessive blow by and found none.
I removed the small return pipe which is on the rear main cap. It was not plugged and not up too far into the cap. The return pipe is the proper length.
I ran a wire into the gallery at the bottom of the rear main cap and it did not run into any obstructions.
My guess is that either there is too much oil flowing through the rear main or there is an obstruction preventing the oil from returning through the return pipe.
I can not check for an obstruction without removing the rear main cap and I can not remove the cap without removing the engine from the car.
I was told that prior to the recent installation of the engine in the car the main bearings were checked and any shim adjustment was made.
The amount of oil leaking was so much that it might be more oil than can drain down the oil gallery and out the return pipe at the bottom of the rear main cap. Does anyone know how much oil would be too much for the gallery / return pipe ?
What next ?
Try to blow air up the oil return pipe ?
Use a syringe to force oil down the oil passage from the oil pump to the rear main and see now much comes out the oil return pipe and how much comes out the rear of the rear main ?
Remove the engine and recheck the rear main ?
Bob
What next ?
Bob
