Model B Crankshaft
Other than the obvious (journal/rod diameters) the only other issue I've heard of is a tendency of the rods to hit against the sides of the crankcase. I believe the B block is relieved a bit for clearance at this place.
It is possible to compensate for this.
I explored the option but have yet to act on it.
Joe K
The main beartings will need to be cut down to model A size. You will need model B or aftermarket special connecting rods. If model B rods are used, special rod nuts will be needed or the oil pan will need some minor mods to clear.
The minor mods of the oil pan are extremely minor. Bolt the pan in place and turn over the engine. A rod will hit the pan. Remove the pan and with a ball peen hammer install some clearance for the rod. You will have to R&R the pan at least 8 times to get all you locations marked. Not rocket science. :D
Thanks, it all sounds rather simple, just time consuming and a few bucks for the machining.
Hey davey,
The rods will clear block, but will touch pan..ergo pan dimples, as said. You will have the benefit of larger/stronger rod journals and use any B crank that you wish to do this, i.e.- Ford first edition..without counterweights, right up thru C crank.
If I were you, I'd get a copy of member Jim Brierley's book and you will not only have answers to the instant inquiry....but much/much more, IMO :) ! And, if you do not comprehend what you are reading (my problem,eh :p !), you can contact Jim B to clarify such. He (Mr. F.A.S.T.) is easy to talk to and most knowledgeable !
The beaver tail crankshaft isn't a mobel B crankshaft. The beaver tail crankshaft was used in 1928 and has the same journal sizes as the later model A crankshaft
daveymc29,
I recently did this. Had the mains ground to standard A size and used Snyders B rods which had nuts that did not contact the sump. Also fitted a modern rear seal which I hope will not leak too much. I expect to run this engine in the next month or so.
Cheers,
Gavin
The oil slinger is a different size and needs to be machined to fit the A block if it is off by just a few thou diameter, thickness and taper it will leak
find a machine shop that has done this
or you have you have it machined for a modern seal easier
