CA Victoria
- City
- Templeton
- State
- Ca
- Price
- 45
Model A Intake for B Carb
A really nice Model B Raised Letter Carburetor.
Sold
It was disassembled and cleaned and I exchanged the better parts from my Zenith parts to re assemble this one with.
I did not remove the plugs but did run it thru the media blast cabinet with fine glass bead media. I did not flow the jets but they are all original ford. The throttle shaft is in good shape, I measured .0025 wear on the lever side & no appreciable wear on the engine side. The float shown is the last one I had. It has a crease and needs a dab of solder over the corner of the crease or to replace it. All parts are present except for the GAV driver, fuel filter, and a gasket set. Sold
I also have a late Model A intake with the up tube bored larger for better flow that was intended to use with a B carburetor, (update: sold as an option with the carb or separate if the carb buyer does not want it) $45 + shipping
Sold
