Terry NJ
The test results I was referring to were posted more than a year ago. Thanks for posting the Vince Falter, Ford garage. I went there and could not find what I was referring to, so once again, my memory has failed! Nothing new about that! Thinking about it, I seem to recall it was someone in Texas.
The reason I referred to the B3 carb was that was the one with the most refinements, being the last evolution before the engine was discontinued. I realize that Ford saw they had problem with stalling in the old A carb. and refined it in their new B carb.
Terry
Terry
Just for clarification, I did not post any test results from the B carb.
Also it should be noted that all versions of the B carb have the float hinged the same, 90 degrees different than the Model A Zenith float.
This is true regardless of the style/shape of the B float. The B float hinge pin is aligned with the fore-aft axis of the car.
