There is a removable brass plug in the upper housing that has a vertical slit in it that is open to the throat of the carburetor. Careful tap it inward until it falls out and check the top of the idle passage under this plug for rust and dirt...
There is a removable brass plug in the upper housing that has a vertical slit in it that is open to the throat of the carburetor. Careful tap it inward until it falls out and check the top of the idle passage under this plug for rust and dirt. Also, under the GAV is prone to rust also and the GAV is pressed into the lower body of the carburetor. If you haven't removed to GAV totally, the engine will never run right.
