Model a Victoria floor pan question
The answer is it is the well for the rear seat foot space
However not quite that simple.... there is another metal pad that the inside rear corners of the from seats rests. It is a necessary part or the seats would dangle on the inside corners
Probably someone will post a pic; I don’t readily have one handy
Dewshan, in the photo you posted, you have everything you need! That piece of steel with the 2 rivets holding it to the frame, is what the “inside” seat post rest on.
Sorry
I did not open the link
Yes it’s there .looks
Like you have early seats with the adjustment on the floor
And the rod
The part circled is were the rest of the front seats set.
The inside back corner of the seats... are they supported by anything? Just bolt in the front brackets and that’s it?
Thanks. I updated the picture link above with pictures of the original rear seat. I’m surprised it survived! Needs upholstery eventually of course!
Here are more photos of the rear floor pan in the 190A that are also common to the 400A.
