Model A Towbar
Nort
Anaheim
Ca.
Price
SOLD
Model A specific, I know, finally you say.
This is a Towbar for a Model A, bolts through the bumper bracket bolt holes in the front frame horns.
So, you do need to remove the front bumper to use it.
It's in excellent condition, used about half a dozen times.
I would prefer local pick-up,
as this item is large & heavy, so shipping charges would be expensive.
Price SOLD plus shipping, local pick-up is o.k. & actually preferred.
I would suggest Greyhound. Very reasonable for shipping just such an item in the lower 48.
Randy,
No, you don't have to disconnect the drag link.
Any other questions, I'll be glad to answer, just send me a p.m.
as I check for those, but don't always look at the forum ads.
Thanks,
Nort
The Bolt Holes?
I'm assuming you're referring to the holes where the tow bar bolts to the
frame horns.
they are on each side where you can see the tube flatten at the end.
what gauge is the tube?
hard to measure as the only open end of the tube is under the tongue
measured with a dial caliper wall thickness approx. .070
the outside dia. of the two main tubes is just over 1.500" (1-1/2")
the outside dia. of the crosstube is 1.690" (1-11/16")
Thickness of the triangular reinforcing plate is .250 (1/4")
hope that answers your question.
