It should run better than you state...even it is not "just right".
Put the timing pin in the depression in the timing gear. Fully retard the spark lever, then loosen the screw on the distributor cam and place the rotor where it is in this picture...
Tighten the screw and put it back together. This should be close enough for the car too run much better.
Now, figure out what went wrong when you timed it and give it another try.
Tighten the screw and put it back together. This should be close enough for the car to run much better.
Position it where the actual rotor is or where the dotted outline is?
