I haven't used the tool, but have used Ford's original timing method and find it easy to set timing.
Marco's way is also easy and works well. In a nutshell you just press the timing pin into the cam gear recess and make sure the rotor is positioned as in my picture. Just lightly press the rotor clockwise to be sure any freeplay is in the CCW direction, since that's the way the rotor turns.
wouldn't that remove freeplay from the CCW direction, not create it?
Why would Marco's method require a ohmmeter or light?
You guys overthink everything and make simple jobs difficult.
No wonder you struggle with everything,
Get a copy of the Instruction Book and the Service Bulletins and do things the easy way.
I do agree with you on one thing -- THINK before you type.
You just need someone with experience to walk you through the procedure. you don't need a ohm meter, trouble light, test light or power to do it the old school way..just a pair of eyes
...A real good tool to have is the crank wrench to turn the motor easily for the timing pin dimple...
That looks handy - anyone know if these are still available anywhere?
what I can't understand is how the service bulletins talk about tightening the screw without any kind of tool to hold the cam in position....did the original setup hold its position better somehow?
I am new to the Model A Forum on Ford Barn and have a question.
In Snyder's catalog is a Timing wrench that caught my curiosity, the Nu-Rex.
I went to youtube and watched a video using this Nu-wrench an was wondering the thoughts you would have about this.
https://www.youtube.com/watch?v=OGAKWX158H8
Nurex makes their money scaring people into buying modern products.
Learn the timing method Marcos has on his site and you are set for life.
As far as points go, a quality used set of points is likely to last you decades with a good cam that is properly lubed.
The whole alternator, V8 points, and timing bracket are just a waste of money and time.
Although Marco's method is best, it also requires a trouble light or an ohmmeter to do it. The Nu-Rex tool requires neither. In fact, you don't need any electricity at all. That makes roadside repairs much faster and easier. For those of us that use a real pop-out ignition switch, the Nu-Rex tool is SO much easier and faster.
