Model A steering box question
rich demo
I have a 1930 Model A chassis that was restored. It has a different steering box installed, but uses the stock light switch at the base, and the stock column and wheel. The box is larger with wider attachment spacing. The sector shaft is round, not tapered, and has a notch for the pitman arm pinch bolt. Anyone know what this box came off of. Thanks
Model A has a square shaft, not tapered or round. Not sure how well around shaft would work? As suggested, a picture would help.
592809
Thanks guys my wife's phone says it might be an AA
Probably not. AA after October 1929 used the "Gemmer Type" two tooth sectors exclusively.
Google AI: Model AA two tooth steering
Ford introduced the Two-Tooth Steering Box during late 1929 production as an upgrade over the earlier seven-tooth design for both the Model A and Model AA trucks, using it through the 1931 model year.
The query goes on to the reasons why as in two tooth being more durable, adjustable, an tolerant of wear.
Neil Wilson (aafords.com) does not yet address the subject.
Joe K
i have been finding more and more,that the letters AI stand for always incorrect on the Model A Ford.People have waved their phones at me saying,lookit it's right here.Some of the BS is just horrifying,and some are taking it as gospel.
Which is why when I reference Google AI (or any other of AIs) I give it verbatum - and with attribution.
In this case it is up to the reader to take on what they wish. I become only the deliverer of information.
If I have any doubt about what I deliver, I indicate that as well.
The point is to augment DISCUSSION - not necessarily to establish or question AUTHORITY.
I suppose I could have mentioned the various "aftermarket" modifications done to the AA, which certainly would include almost anything installed up until WWII. The "Green Book" (Ford Chassis 1928-1947) indicates "date ranges" for the various part iterations - but something as ubiquitous as a steering box, or even a transmission might have been subject to "change-out" to the improved later version.
Ford themselves did that in cases such as the Model A 4 speed transmission, which was recommended to be replaced with a "Model B" variant of the same thing.
Joe K
Any search now days is going to have AI. They generally have little foot notes next to answers. Check those links to try and get more information about where the ai looked. Look at links for context and origin. If you Know it's reputable, then you have some indication of authenticity. If you aren't sure then make statements that indicate that. AI is not inherently bad but it finds what it can from it's data base. Crap in equals crap out when it comes to on line data.
Picture of the mount flange of a F-100 box along with another showing the notched sector shaft. Pitman arm showing the splined area opposite the pinch bolt is in the picture too.
We have also drilled new mount holes and cut down the flange when putting F-100 boxes in Model A frames.
