Upstate gearhead
I'm trying to rebuild a '28 that has been sitting a long time. I rebuilt the Tillotson square bowl carburetor. I had to take .030 off the top float flange to get it flat. I adjusted the float so that I just got gas pouring out, then lowered it 1/32. The only way I can get the engine to fire is to advance the gas rod 13 notches. Timing is 2 degrees past TDC. Choke is 2 turns out. Idle screw 2 turns out. What do I need to adjust to get this to run right?
Thanks for your help.
