Kohnke Rebabbitting
Brent, the blue Print is a nice touch, but the print is for the main shims, both brass, and steel which tells you nothing for what was used in production. I know you thought you had me, but no.
So here is a Question, if the Ford guy says he has a sack full, (he didn't say zip lock, or Potato sack, or I missed it) and I have had 3 single shims, and he has taken 20 motors apart, and we have done about 500, and all were brass and many at that time were very low mileage engines form water cracks, blown rods, ect. So where is the 50 gallon barrel of steel shims we should have to have gotten rid of, from engines with original Babbitt, as they were always Brass.
The Model T's were brass, the B's were brass, and the model A's were some how thought to be better with steel, I think not.
So from what I know, Brass was used in production, like all other engines of any make, and the cheap steel shims could be had for replacement.
So I think that the Ford Guy shows that with his replacement shim bag that has steel shims in, were the replacement parts.
If it were the other way around, there would be Brass shims in the sack.
Herm.
Herm.
