Hard Times, post #7: "The integral running board/splash apron (with separate 'nose' piece tacked to front fender) is for EARLY 1930."
Not quite true. Actually, it ran for the entire 1930 production year, with a mixed configuration of both types in the last quarter of the 1930 production year.
Referring to the RESTORATION GUIDELINES, pg 13-6:
"From the introduction of the 1930 Model, through September 1930, a two-piece shield [splash apron] was used. The front portion was spot welded to the fender. The remaining portion was an integral part of the running board. Beginning in September 1930, a one piece shield began appearing. The transition from the two piece shield was completed in all plants in December 1930."
These GUIDELINES really are an important resource that should be in everyone's Model A library. They do an excellent job of clarifying a great many 'grey areas' and correct a great many half-truths and erroneous information. Like me, a great many of us old codgers 'shoot from the hip' relying on faulty memories of what we once knew, as well as passing on our own long held beliefs - some valid, some of questionable validity.
Sometimes, when I really need to know the actual documented and validated 'truth', or when I question an answer, I brake down and pull out my GUIDELINES to get the real truth. They have been a tremendous help to me over the years.
- Doug Vieyra - older than dirt,
with a memory as clear as the Oklahoma Dust Bowl
