I would say "Not a good idea", but possible, see https://www.speedwaymotors.com/Spee...MIuayKw_ab7gIVoyCtBh3_KgFDEAQYASABEgKupvD_BwE and others I am sure. Once you remove the torque tube you need to add brackets to stop the twist of the axle. The rear end isn't particularly strong. If you are going to build the brackets you should just go with a later rear end.Not possible.
This forum is for questions to the editors about the site. You should post your question here for better results: https://www.fordbarn.com/forum/forumdisplay.php?f=3Looking for an adapter to convert Model A rear driveshaft to modern driveshaft yoke
