21/32 socket 12point.1929 Model A
With the engine in the car, will a box end wrench loosen the rear main cap nuts for a bearing adjustment? Or do I have to build a special wrench? I built this engine a while back and have put a lot of miles on it & it's starting to get a little noisy.
That is what I used. Did a test to see what torque the main cap nut had when done using a modern beam torque wrench. Found that using the tool as intended, the nut was in the 80 foot pound target range.This is a mechanics tool from the era, square on one end, hex on the other, and the length is such that you can get the bolts tight enough, but not too tight----in the era of no torque wrenches
Well now you have!Hard to find,but proper size for caps and piston rods.per Henry Ford.I have never seen a 21/32" socket. 17mm is easy to get (I've got several)
Have you heard of UES International company from Australia? My son is UES USA Inc CEO here in the U.S.Been in Australia since 1904.Close by,? Next time he's in Aust. he can drop off a socket to you.I doubt any tool shop will carry such a rarity. There are not many imperial tools about these days. It's been 50 years since we converted.
Yes, the top of the bolt is "D" shaped and is wedged in there. It will not come out or turn, when you are accessing it from below.
