Model A Rear End
Fozzie
Belleville
MI
Price
$200.00
Model A Rear End, with a 3.78 gear ratio for sale. I believe this is a 1930-31 rear end with the reinforced bango housing and the torque tube has a tapered section behind the u-joint housing approximately 14 inches. It has good round perch balls; good threads on the axles; good round spring shackle bushings and good bearing races. This rear end is minus the backing plates and brakes. Pick up only from my home. $200.00 etsaboy@aol.com
Hello - you and I live a bit too far apart, but if you know of someone coming towards Chicago area (even south bend) I would be interested in the rear end. steve 708-687-4183
