OLD REK Junior Member Sep 15, 2014 #1 Is the rear window panel on a '27-'28 coupe the same as the panel on a '27-'28 2 door sedan? Thank you.
T Tim B. Senior Member Sep 15, 2014 #2 Answer appears to be no. 26/27 coupe is 25 11/16 X 11 15/16 (MAFCA posting of Snyder's T Glass dimension booklet) 28 coupe/Tudor is 23 11/16 X 10 11/16 (1928 service bulletin)
OLD REK Junior Member Sep 16, 2014 #3 Thanks Tim. I guess my first mistake was the model years in question. I should have said " Is the 1928 and 29 Model A coupe rear window panel the same as a 1928-29 Sedan rear window panel?"
OLD REK Junior Member Sep 16, 2014 #5 Actually, I was talking about the sheet metal body panel with the rear window hole in it?? Does that make sense??
