John Tumolo
Any Barner restore a 28-31 Model a Pickup bed and can tell me where the 10 square metal pieces go that I got in a parts kit to hold down the bed strips? JOHN 856 468 5107 Thanks.
I have these square washers attached to the bolts that hold the metal strips in place. .
I believe the wood and hardware on my late '30 PU is original, but I would appreciate an expert to verify this.
Are these the pieces. They hold the wood strips down.
OK, I have a picture of the underside of an original bed. It came from the Mack Hil's booklet. It is in rough condition, but you can see the grooves on the underside. SeaSlugs, I believe is correct. I still believe the bent in part of the square washer goes into the space between the wood planks. Note the orientation of the square washer in Mack Hil's picture. I guess it probably doesn't really matter which way they are oriented. The underside of the original bed in the picture is too far gone to determine which way the washers were installed. I don't agree with 1930-pickup about the grooves or the "bit into the wood". The washers can't move much either way - either between the planks or in the grooves.
Rusty Nelson
Rusty is correct about the square washers, here's a photo of an original assembly from a May '29 original pickup.
The original boards did have the grooves cut on both sides of the boards.
-DAN
I can state that that is true for the 1931 AA deck wood. Milled both sides on an original I took apart. Round washers were found rather than square.
1930-Pickup,
The picture in Mack Hil's booklet doesn't say what year the bed was, but did said it was an "original" bed. The pickup bed floor wood kit I bought on eBay had grooves on both sides. In addition, the wood was marked "TOP" on each piece where the metal stripes would cover up the markings. Some of the undersides were not quite as nice as the side marked top, which tends to support SeaSlugs posting. Just guessing, I suspect sometime in the last 87 years the wood floor in your bed was replaced. I think it would look pretty rough if it were the original, as pickup's weren't treated very nicely (garaged) through the years. They were used hard and left mostly outside.
Rusty Nelson
It appears that I must concede that the boards are grooved on both sides. Its good to get to the truth, but bad that my bed wood is not factory original
My truck was taken off the road and stored indoors approximately 1963. It was stored near Fullerton CA which is a pretty good rust slow-growth area.
It was returned to the road about 2014 by the PO.
The bed wood is aged, cracked, and warped. The underside hardware seen in the photo (posted earlier) is rusty and may be seized. The top of the boards are properly sized and grooved.
Prior to the mid-1950's, were Model A vendors supplying wood bed kits, and would it have been a fairly common practice to replace bed wood?
yes but like previously mentioned that bent corner should dig into the wood - your right bolt is not and your left one barely is.
