chopsaw209
- City
- Orange
- State
- CA
- Price
- 7,800
1929 Ford Model A sedan to truck conversion project for sale. CA titled, plated, and registered. Solid 80% complete hot rod project for someone to take and make their own, so have some fun!
Text 714 two77 zero zero 17
or email ctalley@keyonestudios.com
Here are some photos and spec details.
Note: Will also consider sale without motor and trans for lower price.
Note: Not really interested in trades, please lets keep the low ballers on the other websites
See this link for LOTS of photos
http://keyonestudios.shutterfly.com/pictures/8
Details:
Has CA title and plates, modern not original 1929 plates
1989 Mustang Ford 302 High Output version roller rocker motor
Weiand intake w Holly 600cfm 4bbl
ORIGINAL Cal Custom aluminum valve covers
C4 Trans with manual valve body and hi stall torque converter
New hi torque mini starter
Lakester Headers
Lokar tall shifter, mounting bracket, and linkage
Ford 9" Rear end with highway gears NO POSI
Custom made to fit drive shaft new balanced
1930's spoke front wheels with roller tires
Custom steelie rear wheels with zero miles Hurst cheater slicks
Model A frame boxed, with front kick and rear Z, rear half is box tubing, has mounts for reversed Corvair steering box
All new pete & jakes shocks front and rear
Most brake lines are complete, still needs front done and adapters for thru frame front lines.
All new front end:
4"drop Superbell axle, new spindles, new kingpins, bearings, shims, etc..
40's front drums and hand drilled backing plates, new wheel cylinders, new brake pads.
New master cylinder with power booster
Cab and Bed
Original Ford cowl, doors, cab corners, rear panels, firewall, modified recessed lower half, original Ford bed and tailgate
Hand made "B" pillars to stretch cab 2" in length
Original pick up rear panel and cab corners chopped to match stock tudor sedan height
32 style reproduction steel dash with original Champion aluminum finned insert with 2 Dolphin gauges
Mr Roadster bearing sealed steering column
Bear Claw door latches
Louvered original visor
New reproduction wood kit, with water seal and stain
Needs:
Grille Shell
Radiator
Headlights
Glass
Steering box, D shaft and joint
Some motor accessories
Trans cover plate
Minimal brake line work and parts
All wiring
Other minor things I am not thinking of right now, but small potatoes in the big picture
Details:
Lakester Headers
All new front end:
Cab and Bed
Needs:
Grille Shell
Radiator
Headlights
Glass
Trans cover plate
All wiring
