Cockshutt Kid
Good evening guy's. I learned to drive on a 31 tudor, and last summer I replaced it with one that is almost identical. It was restored in the early 1980's. The body appears to be excellent, with a decent interior, and it runs fairly good. Paint is starting to fail. Last winter I redid the steering as I was not happy with it. I put in a new sector with needle bearing housing, shortened pitman arm, and nylon inserts in drag link and tie rod ends. Waiting till the shop doors thaw out so that I can try it.
Now to my questions. I live on a busy highway, so I would like to get a little more speed out of it. It runs comfortably at 40mph, and ideally I would like to be able to run at 50 to 55. I am assuming that the engine rebuild at that time was probably a set of rings and file the caps. That was the norm around here, because the closest shop able to do much more is a long way off. Today I picked up two A engines and a B engine, just on speculation that I might need them. I have not opened them up yet, so i have no idea as to condition or what is inside. I also got a B transmission.
I would appreciate some opinions and views on what I should do and how far I should go. I am starting to plan for the future, and find what I need now.
Thanks, I appreciate all views.
