lake_harley
- City
- Uniontown,
- State
- MO
- Price
- $900
Complete, disassembled stock engine that was running about a year ago. Magnaflux showed cracks across the exhaust ports on the two center cylinders when I began to get serious about rebuilding it. The pistons from the engine are .080" over and are quite re-useable with a bit of cleanup. I also have a second block and crank (journals are nice) but the block would need babbit or conversion to insert bearings. I also have an extra set of rods and pistons. Model B carb and distributor for rebuild cores. Fresh Brierley reground "C" grind cam which has more lift and duration than a B cam. Stock clutch, bellhousing, transmission and torque tube. Model A rearend that has been completely disassembled, cleaned, painted, bearing preload set, new seals and converted to open driveshaft. Front Model A spindles, hubs and drums with brakes. Front and rear Model A brakes have been converted (by me) to hydraulic, similar to Ansen kit of years ago.
There are a few other Model A related parts that would be included but are not in photos and not in this listing of parts. Package price is $900.00 I will sell individual parts. Contact me if you have questions.
Location is Southeast Missouri.
Lynn Winter
(573) 788-2574
Lynn Winter
(573) 788-2574
