Model a paint code help please
Modelakid31
Hi everyone. i was wondering if anyone knows what the closet or exact brewster green paint code for dupont paints.
Also show red or gray primmer be used instead of white?
Thanks in advance eveyone!;)
I suggest that you try www.tcpglobal.com for the codes. They have all of the early Ford color chips and original codes online.
I prefer to use PPG K-36 which is a light gray, almost white as a base under all of the colors I spray. PPG does allow K-36 to be tinted so you could tint it Brewster Green to help insure the true color in the final color coat. I suspect that DuPont has similar systems. Gar Williams
