fordfun
My recently acquired 1929 Sport Coupe came with a B head, B water pump and B carburetor. Can you help me determine (from the attached photos) whether it contains a Model A or B distributor and timing cover?
The distributor cam appears to resemble that of the model B (flats blend with radius). The timing cover appears to be a replacement, but the hole for the timing pin is in the lower part of the flat, suggesting that it is the original model A configuration. I understand that mismatch of these parts such as combining a model A timing gear cover with a model B distributor may require that allowance be made in setting the advance during timing.
I’ll greatly appreciate any guidance you can give me regarding model identification of these parts and the corresponding way the engine should be timed.
Thanks - Bill
Thanks - Bill
