Randall
I did a pretty in-depth test on the valve cover style oil filter you fellas might like,
https://www.youtube.com/watch?v=9YXjaxxC7rE
What are the advantages of the bypass filter? Why would one chose the bypass filter instead of the full flow?
W. Michael
W. Michael
If you are switching from non detergent to detergent it would be a good idea pull oil pan and valve cover and clean, because of the screen around oil pump
- About 30% cheaper
- Most people think the bypass kit looks better
- Permits installation of a filter with a smaller micron rating
- Theoretically it could reduce the risk of the filter clogging, e.g., if you are switching from non-detergent to detergent oil and are worried about lifting sludge into suspension
In the video it took close to 2 minutes to fill the filter and get oil flowing into the engine, that's scary. What shape is the pump in? If you take the actual filter off the adapter, how long does it take to for oil to come out the adapter? What speed are you rotating the camshaft at? Methinks it should be at least 200 rpm.
As per Paul Shin he suggested drilling out the backflow gasket. I instead cut slits with exacto knife.
I am using a Wix filter on the valve cover style oil filter. As per Paul Shin he suggested drilling out the back flow gasket.
And here we go again...
