BetsyModelA
Thanks Rusty. I'm not giving up yet.
Betsey, I assume you've been rocking back, in third gear? Try putting it in reverse. The idea being to turn the engine in the opposite direction. See if you can get a little motion out of the fan turning it backwards.
Terry
Yep, some cylinders will drain down because of some open valves. It's apparent that the pistons are stuck, so concentrate on keeping pouring stuff in the spark plug holes. Bill W.Bill, there seems to be an overflow with only one of the spark plug holes. Should I put in more? If I thought it would help, I'd drain the MMO, put in the ATF/acetone solution, and give that mixture a try. What say you?
I am in Bismarck, and have 6 Model As. I also have built one of the tools that Tom describes. I may be able to come to Harvey sometime soon if you wish.
