You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Model A motor and trans weight
Does anyone have an online ref. to the weight of a Model A motor and trans. from 1929 ? Thanks
Don_Bski@yahoo.com
Weight (Lbs)
Short Block
207
Long Block
358
Engine Ready to Run with Manifolds, Carburetor, Generator, Starter & Less Clutch Housing & Transmission
400
Running Engine with Flywheel, Clutch & Transmission
473
Camshaft
Clutch
Connecting Rod
1.375
Crankshaft (No Counterweights)
28
Flywheel
63
Piston, Rings & Pin
1.55
