Model A lubrication chart
burner31
Anyone have a usable/readable (for these old eyes) of the Model A lubrication chart?
Can't seem to find one online that I can zoom in on and read clearly.
Also having problem visualizing location: (from pg14 of model A instruction book)
*Approximately every 2000 miles, lubricate the clutch release
bearing. This is done by removing the hand hole cover and
turning the bearing until the lubricator fitting is at the top.
Lubricate the bearing by means of the compressor grease gun.
What's the hand hold cover and where's that bearing?
Going to Okemah this weekend, may stop by and help you identify the lubricating locations, thanks, Joe in Denver
I bought the large lube chart at a national meet, but I think all the parts houses sell it also. It's nice to frame and hang on the garage wall.
I believe this statement is referring to the early cars that used the multi-disk clutch. The clutch release bearing (throw-out bearing) had the grease fitting in the bearing and you had to rotate the bearing in order to get at the grease fitting. The hand hole cover must be a reference to the little removable plate on the top of the bell housing.
Tom Endy
That's a very kind offer Joe, I'm going to Missouri this Saturday, to look at some parts, and have dinner engagement this Sunday.
I'll PM you and maybe we can still do this on both our schedules.
Keith
According to the V8 service bulletins Ford changed to a sealed throwout bearing starting in 1935, so if your bearing has been changed since 1935 it is probably a sealed bearing anyway.
And remember, if you have your sealed T.O. Brg out, they can be re-packed with a wheel bearing packer. I even re-pack a NEW one. Sometimes the Factory Grease is like VASOLINE!
Bill Slick
I often pop the seal off one side of a sealed bearing, so I can check the amount of grease. Quite often there's barely enough to smear on a fingertip. In other words many rebuilt parts have just enough grease to make it to the end of the warranty.
Like this? Vendors sell, Take to print shop have enlarged.
Here is a photo of the lubrication chart that I have hanging on my garage wall.......hope it helps (and that you can read German!):
573098
Brad in Germany
Brad,
das ist ein sehr schoenes grosses Plakat! Sehe ich nun zum ersten Mal. Wird sich hier in D. leider nicht finden lassen.
Gruesse aus Aachen,
Werner
