Tom Wesenberg
I had a similar problem in the woody. After changing the entire engine, carb, dist, manifold with a set up that was previously proven to run well in my sedan, the problem persisted. The station wagon had a BW overdrive, which I suspected was contributing to the problem. Later on, during a ground up restoration, I found the splines in the drive shaft collar to the BW were worn. I theorized that with the excessive wear, even the slightest hickup in the engine from either a too lean cough when cold or a too rich loping effect from loading up on a long down grade was ricocheting back and forth through the excess drive shaft slop. Having the splines and collars rebuilt solved most of the bucking. There is still some occasional light bucking on long down hill grades. I suspect there is wear inside the BW as a result of the bucking from the worn splines. It could be your U joint and the drive shaft splines are worn too much.
I too have been trying to think of a mechanical reason for the bucking. I think you may have hit on something worth looking at. Also check the rear axles for tight nuts and keyways. I'd put the car in high gear and push it by hand back and forth to check for slop in any of the driveline. Also check that the front and rear axles and wishbones are not loose.
