Model A horn
Ron Barber
Horn picking up a ground and runs continuous. Has anyone had this problem? The horn works great and checks out ok. But when grounded to the frame it will run and heat up at times.:mad:
The horn works by passing the voltage through the horn and up to the steering wheel where it is grounded. I would check the bottom of the steering box where the light and horn connections are made. If you have a reproduction harness anything can happen.
Some of the poorer quality wiring harness terminal block horn connection will **** sideways and ground out in the switch.
Ron
Mine was doing that and the insulating washer between the frame and one brush holder was missing. I may have left it out before while trying to make it work.:eek:
I found it by using my ohmmeter probes at each point of the circuit until I found it.
Every time I see that happen it was because one of the brush holders was grounded. There MUST be an insulating washer on each side of the motor frame. So, you have the brush holder, insulating washer, motor frame, another insulating washer to fit in the countersunk hole, then the mounting screw. You need this on BOTH brush holders.
You can make an insulating washer from thin fiberboard, or even an old credit card. Something like the cardboard from a cereal box WON'T make a good insulating washer.
