BButturff
I realize the “How to”, “When to”, “Which head gasket”, “Which torque patterns”, "Sealant/no sealant" and “Hot or cold” of torquing a Model A cylinder head have been discussed at great length in these forums. I've even read a couple of posts that covered how much better the head clamping force would have been if it had been designed with more studs. Additionally, I've read that higher compression aftermarket cylinder heads are recommended to be torqued to 60 ft/lbs (or more) for additional clamping force.
So here's my humble question. When we go to the expense of rebuilding an engine, why don't we install larger diameter head studs that can be torqued to a higher spec? Without knowing the facts it seems easy enough.
