Some of these thoughts just 'kill me' because I think some of you are truly sincere in believing what you typed. I like Mike's thought about didn't they drive them daily when they were new!
Duhh.........
In all seriousness, it honestly does not take many (if any) modifications to maintain 50mph or less in a Model A if
everything is within original specifications. Now just like most of us would not drive a Chevette w/ 100,000 miles in the left lane on the German Autobahn with their flow of traffic, the same applies to driving a mechanically worn-out Model A at 50mph.
Reading between the lines based on a couple of comments you made, if you are thinking you can have a Model A engine rebuilt without spending much money, IMO you chose the wrong vehicle! Spending the extra dough for higher compression is something that I feel is prudent. Spending the money for a brand new Stipe camshaft is another thing that is prudent. I know some people out there brag about their "reground" camshaft and how wonderful it is, but I have no financial stake in either type however I do have a bunch of experience with engines that have had both type cams, and IMO the new cam is the one that outperformed the "regrind" based on the entire drivetrain we typically spec out at my shop.
Now here's how I see a daily driver broken down financially. To take a typical 'restored' eBay Model A and turn it into a driver capable of safe, right-lane freeway speeds, then a minimum of a 60 horse rebuilt engine consisting of a H/C head, a new cam, oversized intake valves, correctly poured babbit, and a
thoroughly balanced engine will be needed. Prices will be all over the place for this but generally speaking, the minimum will be around $3,000.00. On the outside will need to be a properly rebuilt distributor and properly rebuilt carburetor. These are two items that consistantly are found to have been poorly rebuilt and can severely limit horsepower capabilities.
The next area that will need to be looked at it the rear end. I am a huge fan of the 3:54 gear ratio because it adds as much as 4-5 mph at freeway speeds over the stock ratio. Following the rear end will be the brakes in which one can usually plan on investing $800-$1,000 and some of their time bring
each, &
every item back within factory specifications. Good quality new Cast iron drums are a must have too. Next, ensuring the spindle bolts (King Pins) are tight, the steering balls are all round, and the steering gearbox is adjusted properly and within specifcations is a must for safety. And finally, IMO no "driver" Model A should be without a good quality shock absorber on each corner of the vehicle. The control and stability that properly operating shocks afford to a Model A's safety should make this a mandatory item. Now, the problem with all of these above mentioned items is that in all liklihood, you will need to spend over $5,000 to make these operations, ...and more probable in the $7k-8k range, --which most feel is too much money. When I ask "why" is that too much money, the typical response is I just want a Driver.
When I ask why their steering has so much play, or the brakes nearly go to the floor, or there are no shocks on the car, they just act like I don't get it or understand.
