O oldford Senior Member Apr 11, 2025 #1 Will the above tool work on a 1932 B model engine. I think it holds the oil pump in place when oil pan is removed.
O oldford Senior Member Apr 11, 2025 #4 DavidG said: Yes, but unnecesary. Click to expand... When the oil pan is removed want the oil pump fall out.
DavidG Well-known member Apr 11, 2025 #5 Not if you think about it in advance and the original retention set screw in the block is still in place.
