CA Victoria
- City
- Templeton
- State
- Ca
- Price
- 400
Stamped as a Ford Replacement Engine *RFxxxx*, I believe the RF stamp indicated it was from the Richmond Ca plant.
De greased and stripped.
Cylinders currently at .090 without a noticeable ridge, should clean up nicely or re sleeve to std.
Mag check done, no cracks detected.
2 broken studs, one heli-coil
Comes with main caps, rod cores, covers, re ground crank, adj. lifter cores,
B cam core, oil pump, pan, A head.
No rear flywheel housing or flywheel
On a roll around stand.
Pickup only
Close to Santa Margarita FAST Time Trials or RPM Nats
$400
Pickup only
$400
