It's a new Battery, new Relay with Diode.
Thanks,Tom. Are you saying that only the one filament should light on the Bright setting?I like and use original connectors..............repro connectors aren't so great and sometimes short to each other or to ground. Put on a welding helmet and look at the headlamps to make sure both filaments aren't lighting up at the same time.
This is an oldy.
