I did some searching, but I always suck at search. I am pulling the motor and trans from the 30 model a. I will not need motor mounts. The front mount and mid mount look simple. but, the front control arms are attached to the transmission. Will I be able to roll around the chassis when I remove those? Also is the only other rear mount the closed DS?
Are there any threads with a write up?
