Bore sizes?
Had a test bore done on my early 28 model A engine, at 100. over it looks like the pitting will not quite clean up in the bad cylinder when taken to 125.
As I planed using insert Snyder's rods, I could use the other insert rods they sell for running standard Chev pistons?
Anyone using oversize Chev pistons in their "A"?
The rods are designed for 283 standard pistons, at but at 125. + overbore it will be over 4 inch so what pistons do I look for then? 327 or 350 maybe?
The block is going to be tested for wall thickness first and offset grinded to keep the gap as big as possible between the cylinders but looking for info from someone experienced in running such a large overbore.
Thanks Rich
Thanks Rich
