Model A Distributor with Centrifugal Advance
Sheldon Paulger
Is there a 4 cyl distributor with centrifugal advance available at auto wreckers that would fit a Model A (with minimum modifications)?
Thks
Sheldon
Not that I am aware of. Most distributors since the 50s and probably before have a gear on the bottom end of the shaft in the place a shaft retainer would be on the Model A. Also a lot of these distributors are longer than the Model A too - they have the length of both shafts built into the housing.
If you want centrifugal advance, go find a Mallory or B distributor.
In the current market these days I have found that VW and MG distributors can be modified to work
After the machine work is done the advance curve will need attention
John
I had heard early datsuns can be altered but the advance curve is wrong. Model B curve is correct but have design issues. FSI uses hall effect adaptive dwell.Period Mallory distributors for model A, Y 11 series are out there in dual or single point setups.
Prewar English small Fords had a distributor which is a straight drop in . They are fairly common at swap meets here You have to check the rotation as this small engine went to a chain drive camshaft there is an arrow on the rotor to indicate rotation .They should be about in the Antipodies (have I spelt that right ???)My son has one in his pickup and it works a treat . I cant recall what the advance is I must check .
John in sunny cool morning Suffolk County England .
The correct spark advance is 1 degree per 100 rpm,peak at 24 to 26 degrees max.Besides drivability mechanical advance eliminates detonation or spark knock, a cause of bearing failure.High compression reduces the tolerance for improper timing.The increase in engine efficiency is noticeable.
This is a straight away drop in, however, Mallory has been bought out several times and the 4 cylinder distributor parts are extremely hard to find.
John
John
B points and condenser hard to find as well,along with a few internals.The B distributor has a design flaw,the breaker plate shaft/drive shaft get no lubrication and is small in diameter..you can get oil to it through modification.The FSI electronic distributor,either zipper A style or the stand alone industrial body style uses a hall effect style pickup and has adaptive dwell,spot on coil soak everytime.The biggest problem with the pertronix/FSI pickups is the need for clear voltage signal,tying it in with an old sketchy harness and grounds leads to failure.
I use the nu-rex advance on my 2 A's-- they are a great upgrade and easy to install.
Me too. And as a side benefit it is fun to watch 'Ace Mechanics' in the group try to explain why I have so much "play" in my distributor drive. :rolleyes::rolleyes:
The advance built into these distributors is set for a standard engine with a standard head. We know that as compression rises, less advance is needed.
Does anybody have an idea on how much less advance is needed for a 5.5:1 head? Same question for other after market heads that are available all the way up to about 8 or 9 to 1.
I solved the condenser problem by using a high quality Model A condenser from Brattons. I elongated the hole in the tab and added a pig tail. It went right in (see photo). I bought several sets of NOS points a few years ago and haven't checked their availability recently. If I was looking for points (or other Model B parts) I would start with Renner's Corner, (734) 428-8424.
Charlie Stephens
Just buy a FSI Zipper. Has centrifugal advance made for the Model A.
FYI. The fsi Zipper does not work with HC heads. I tried it and had to send it back. FSI admitted that it will not work.
I suggested that they say that in there advertising it is not intended for HC heads, but that went to deaf ears.
