Model A chassis (most of it)
chris101_ny
New City
NY
Price
$2000/neg
I’m building a hot rod from a 31 Fordor sedan. I have a 4 banger, ******, front end and rear end (including brakes) drive shaft, suspension, brakes pedal assembly, steel rear fenders, front fiberglass fenders, original cross member. I’m using the frame and wheels you see in the pictures, body, etc. Supposedly everything has been rebuilt bc the car was in the middle of a restoration. It looks to me like that is true. I know everyone says this, but the car was running when I started taking it apart but has sat a while since, so the fluids need to be changed and carb cleaned out, etc.
I tried to attach pictures but I’m not sure if it worked. I’ll try to add them if it didn’t or send them directly to you
