Model A & B part's
Greg out west
San Pedro
Cal.
Price
Varie's
Hi Guy's
This is the current list of part's for sale.
Set of (4) 371 CI Oldsmobile Piston's (used but good) these are 4" & will fit a A or B block if bored out to .125 or 4"...Rod must be narrowed alittle at the "pin" use a A piston pin,,,Come's with new Chrome ring's
$ 75 for the whole set
Model A rod "core's"
$5.00 each
Rear Window glass Safty type fit coup's & tudor's see Bratton's 41600 for Apt.
$30
73 Pinto 2000 cc dist in nice shape
$25.00
A engine lower water pipe (new)
$ 8.00
2 Piece Model "B" rear main seal Neopreme
$ 25.00
Nice repro stainless gas cap fit'd 30-1
$10.00
Early bell housing no vent' type fit's latter single plate housing
$ 5.00
30-1 Coupe door patch panel's
27 5/16 wide.
$50.00
1 brake cooling ring, fit's steel drum only
$ 10.00
New chrome conduit's set
Headlight's & horn
$ 6.00
Left hand side E brake lever on backing plate
$ 6.00
Quarter window seal for glass
$ 5.00
Early type oil plate clean out plate with spring
$ 10.00
Rebuilt Solid center clutch disc fit 29 to 31
$25.00
New air maze air cleaner with filter fir's all A carb's
$ 25.00
Original throttle assembly fit April 28 to June 29 come's with new spring
$ 25.00
Early 30 original running board splash shield's (set of 2)
$ 75.00
Nice engine crank gear's (2) fit's 28 to 34
$ 5.00 apiece
fuze starter mount "new"
$ 8.00
Set of model A Lug nut's (23) Painted Alumium good for as driver
$ 10.00
Left rear running board bracket (new) fit'a all year's
$ 12.00
3, 19" model a rim's, One painted black the other two are Cream color ready to mount tire's
$ 65.00 apiece
Sent all inquires to me direct At my E-mail address
Grumperman@gmail.com
Thank's Greg out West,
Hi guy's
Here's a few extra part's I forgot to add to my list on Feb 2d
Model A cyl head magnafluzed & surfaced both sides
$50.00
Model "B" dist body Only,with new bushing
$20.
If interested,,,
E-Mail me direct At:
grumperman@gmail.com
Thanks' Greg out West
