vtwinsideways
Ummm guys, the fella said right off that he is running a V8, not an A motor. Looks to me as though Kens kit is made specifically for the A.
He's made plenty v8 brackets before. and thats only one bracket. the rest of them will all fit the same.Ummm guys, the fella said right off that he is running a V8, not an A motor. Looks to me as though Kens kit is made specifically for the A.
Hello,
I know it is blasphemy to think that anyone would modify a Model A ... BUT, modified cars are part of our heritage. With that said, have any of you found an easy to install, after market, air conditioner to install in a V8 powered Model A coupe?
It is time for a little comfort. ( My wife and I covered over 25, 000 miles in our non-air conditioned '31 truck over the last 5 years of summer and fall driving. It gets ridiculously hot in the cab of an A truck when it is over 90 degrees and less than 108 degrees!) Temps over 90 degrees are not uncommon in our part of California.
I have a radiator which is set up for air, so I don't need another condenser. I would like to find a unit which will neatly fit under the dash (gas tank has been removed) and can have vents either through or under the dash.
It would be greatly appreciated if you have had experiences which you could share about such an installation.
Joe
Joe, did you also try and ask on the HAMB site as you have a V8 and not a model A engine?
Thanks for the addresshttp://www.kendavismodela.com/index.html
This might help,,I plan to use this mod when I get to that point as it does get warm here in bama!
I wondered how long it would take the internet police to show up!![]()
To install Ken's AC unit I would need to convert my system over to 12-volt?
Steve
