Paul in Colorado
I will sometimes take my Model A to school activities or youth groups and use the following outline to help them understand how a car works. I will ask the questions, and then show them the parts we are talking about on the Model A. I also use a framed copy of the lubrication diagram to help them see the parts. I have a plastic model of a four cylinder engine that I use to show them how the engine works. They can also get in the car and honk the horn. Both the boys and girls enjoy it, and I hope it may get them interested in our old cars. Besides, it is fun for me!
[FONT=Arial, sans-serif]How do you make a car go?[/FONT]
[FONT=Arial, sans-serif]You need an engine[/FONT]
[FONT=Arial, sans-serif]What does an engine need to run?[/FONT]
[FONT=Arial, sans-serif]Fuel and a spark to ignite it[/FONT]
[FONT=Arial, sans-serif]How does the fuel get into the engine?[/FONT]
[FONT=Arial, sans-serif]From the gas tank to the carburetor – Gravity or fuel pump[/FONT]
[FONT=Arial, sans-serif]What does the carburetor do?[/FONT]
[FONT=Arial, sans-serif]Breaks up the fuel to ignite more easily - Like a spray bottle[/FONT]
[FONT=Arial, sans-serif]Modern cars use fuel injectors to inject the fuel directly[/FONT]
[FONT=Arial, sans-serif]What ignites the fuel?[/FONT]
[FONT=Arial, sans-serif]Spark plugs[/FONT]
[FONT=Arial, sans-serif]How does the spark plug know when to fire?[/FONT]
[FONT=Arial, sans-serif]The distributor sends the spark at the right time[/FONT]
[FONT=Arial, sans-serif]How do we change the speed of the engine?[/FONT]
[FONT=Arial, sans-serif]Step on the gas pedal[/FONT]
[FONT=Arial, sans-serif]The carburetor (or fuel injectors) feeds more fuel to the engine[/FONT]
[FONT=Arial, sans-serif]The engine runs constantly – How can we keep the car from moving?[/FONT]
[FONT=Arial, sans-serif]The clutch disconnects the engine from the car[/FONT]
[FONT=Arial, sans-serif]Push down the clutch pedal to disconnect the engine[/FONT]
[FONT=Arial, sans-serif]An automatic transmission disconnects the engine by itself[/FONT]
[FONT=Arial, sans-serif]The transmission can also be put into neutral – No connection [/FONT]
[FONT=Arial, sans-serif]The engine likes to run in a limited speed range – The car runs from a crawl to highway speeds. How do we match the engine speed to the car speed?[/FONT]
[FONT=Arial, sans-serif]The transmission – Different gears for different speeds[/FONT]
[FONT=Arial, sans-serif]How do we change the gears in the transmission?[/FONT]
[FONT=Arial, sans-serif]Use the clutch to disconnect the engine[/FONT]
[FONT=Arial, sans-serif]Use the shift lever to engage different sets of gears[/FONT]
[FONT=Arial, sans-serif]Use the clutch to reconnect the engine[/FONT]
[FONT=Arial, sans-serif]An automatic transmission does this by itself[/FONT]
[FONT=Arial, sans-serif]How do we connect the transmission to the wheels?[/FONT]
[FONT=Arial, sans-serif]The drive shaft[/FONT]
[FONT=Arial, sans-serif]The wheels go up and down over bumps – The engine is fixed in place[/FONT]
[FONT=Arial, sans-serif]How do we prevent the drive shaft from breaking?[/FONT]
[FONT=Arial, sans-serif]A universal joint allows the drive shaft to move up and down[/FONT]
[FONT=Arial, sans-serif]The drive shaft goes down the length of the car – The axle goes across the car[/FONT]
[FONT=Arial, sans-serif]How do we change direction to drive the wheels?[/FONT]
[FONT=Arial, sans-serif]The differential changes the direction of the driving force[/FONT]
[FONT=Arial, sans-serif]When a car turns, the outside wheel travels farther than the inside wheel[/FONT]
[FONT=Arial, sans-serif]How do we allow this to happen and not skid the tires?[/FONT]
[FONT=Arial, sans-serif]The differential allows the wheels to travel at different speeds[/FONT]
[FONT=Arial, sans-serif]Now that we have the car moving, what do we do when we come to a stop sign?[/FONT]
[FONT=Arial, sans-serif]Step on the brakes[/FONT]
[FONT=Arial, sans-serif]The engine is still running and trying to drive the car – How do we disconnect it?[/FONT]
[FONT=Arial, sans-serif]Push down the clutch pedal[/FONT]
[FONT=Arial, sans-serif]Shift into neutral if you want to stay stopped[/FONT]
[FONT=Arial, sans-serif]An automatic transmission does this for you[/FONT]
[FONT=Arial, sans-serif]How do the brakes stop the car?[/FONT]
[FONT=Arial, sans-serif]The brake pedal is connected to the brakes on the wheels by rods[/FONT]
[FONT=Arial, sans-serif]Brake shoes are pressed against the inside of the drums[/FONT]
[FONT=Arial, sans-serif]Modern cars often use disks and calipers – like bicycle brakes[/FONT]
[FONT=Arial, sans-serif]Modern cars use hydraulic lines to push the shoes[/FONT]
[FONT=Arial, sans-serif]How do we start the engine?[/FONT]
[FONT=Arial, sans-serif]Turn it over with a crank[/FONT]
[FONT=Arial, sans-serif]What if I’m not strong enough to turn the crank? (Or I’m lazy?)[/FONT]
[FONT=Arial, sans-serif]I can use an electric motor (starter) to turn the engine[/FONT]
[FONT=Arial, sans-serif]A small gear on the starter motor turns a big gear on the engine[/FONT]
[FONT=Arial, sans-serif]The starter disconnects when the engine starts running[/FONT]
[FONT=Arial, sans-serif]Where do the starter and sparkplugs get their electricity?[/FONT]
[FONT=Arial, sans-serif]From the battery[/FONT]
[FONT=Arial, sans-serif]The battery only holds so much electricity – What happens when it runs out?[/FONT]
[FONT=Arial, sans-serif]The engine stops and will not start again[/FONT]
[FONT=Arial, sans-serif]The lights and other accessories will not work[/FONT]
[FONT=Arial, sans-serif]How do we keep the battery charged?[/FONT]
[FONT=Arial, sans-serif]Have the engine run a generator (or alternator)[/FONT]
[FONT=Arial, sans-serif]The generator keeps the battery charged so it will start the engine[/FONT]
[FONT=Arial, sans-serif]This car is completely computer controlled. Where is the computer?[/FONT]
[FONT=Arial, sans-serif]The driver’s brain[/FONT]
[FONT=Arial, sans-serif]Modern cars use a computer to do the things the driver does[/FONT]
[FONT=Arial, sans-serif]Who designed this car and figured out how to make everything work?[/FONT]
[FONT=Arial, sans-serif]Henry Ford and his engineers[/FONT]
[FONT=Arial, sans-serif]What would you say if I told you this car just came together over hundreds of years?[/FONT]
[FONT=Arial, sans-serif]That’s ridiculous![/FONT]
[FONT=Arial, sans-serif]If we admire the designer of this car, how much more should we admire the designer of the universe and all that is in it?[/FONT]
[FONT=Arial, sans-serif]How ridiculous it is to think that this universe just happened without a designer![/FONT]
[FONT=Arial, sans-serif]HOW TO BUILD A CAR[/FONT]
