Billybob57
I'm confused as to the proper way to adjust the brakes. Below are the two methods I've found;
*Paul Shimm and Diablo DVD version-
Adjust all 4 wheel brake adjusters until there is a slight drag. Then back off 2 to 3 clicks.
Then install the board on the brake pedal at the 1st notch. Go around and adjust the brake shaft turnbuckle for a slight drag at each wheel. Then with the board at the 2nd notch adjust the brake shaft turnbuckles for a hard drag at each wheel. Then with the board at the 3rd notch adjust the brake shaft turnbuckles so all 4 wheels are locked. Then install all cotter pins.
*Les Andrew's Red Book-
Pull the brake rods forward to take up all free travel without activating the brakes. Adjust the clevis on the brake rod until the hole in the clevis lines up with the holes allowing the clevis pins to be inserted. Then install all cotter pins
Then install the board on the brake pedal at the 1st notch turn the brake adjusters so there is a slight drag at all 4 wheels. Then with the board at the 2nd notch turn the brake adjusters so there is a hard drag at each wheel. Then with the board at the 3rd notch, turn the brake adjusters so all 4 wheels are locked up.
Why the difference in procedures and which do you recommend?
