1946
I have had a container of "Flash lube" near on full. I added 2ltrs of A.T.F. and 100ml of a solvent and have been using that at a rate of 100ml to a 50 ltr of unleaded fuel. You can get MMO here in Aus. but it is so expensive, i have reserved my container of 3gal for my aircraft motor which is over 70 years old. It can be obtained from AVIAL Pty Ltd at about $80.00+ for 3gal.
When I run out of my present supply of flashlube/aft, I will mix a brew of 3 parts marine grade two stroke oil to two parts AFT plus a minute amount of solvent, good in the toyota 22r motor, 2.2ltr Subaru, and of course the 29 A model.
