Assuming you have not changed the transmission or rear end, or added an overdrive, changing the carburetor or the head does not change rpm at a given ground speed. Having these mods might should make it so you get there faster...A B carb, and Brumfield head reduces the RPM a measurable amount?
What they will do is increase the torque and horsepower at that rpm because the engine is breathing better and able to put more fuel/air mixture through.
