Arnold, what diff ratio are you using.
Lawrie
I have the Mitchell overdrive too and love it. My rear end is the standard 3.78 but in overdrive it is very close to 3.00 to 1. I too will use second over then third standard and the reverse when down shifting for grades or lower speeds.
Yes good times, Im putting a Mitchel in my pickup, it has the 3.54,
Lawrie
arnold, 107 mph. That's phenomenal. :d
We putt putted en masse to breakfast the other day. Wife had things to do when we got home so it was 70mph on the freeway home. Sounds like I need a Burtz too......L, Wow, Knowing how well that engine goes, you'd better be careful - there are speed limits.
That said, I had my Burtz over 107 a couple of days ago. Just as well the cops weren't around!
I have posted before that I have 4 Model As and all of them have a Mitchell unit in them. I agree, they transform the car. My most used one also has one of their synchronised gearboxes. It is the car I use when towing the camper. High second is a very handy gear when doing that, especially since I learned how to move from high second to standard third gear in the one action (pull both levers back together).
Money well spent.
I cut my shifter down, its about in inch longer then the Mitchel shifter, i split second and 3rd gear all the time, i shift 5 times from a stop
Had some aluminum round stock , 1”, extended the Mitchell stick.
Got my Mitchell overdrive installed in my 31 Tudor. It drove better than it ever has for me. Drove it 60 miles and it drove better than my 2021 pickup. I will be driving my Tudor a lot more. Best investment I have ever made.
Could you give us the current price for a Mitchel Overdrive? I have a feeling they are around 4k by now with all the inflation.
