You could tell them the stubby one with the button on top is for the 4WD transfer case...
Besides it is fun watching people discuss why it has "three shifters".
JayJay
Thanks everyone for your comments. Did anyone put in an OD with 33% reduction with stick rear end? I am thinking 33 would be a bit much but would like to know your thoughts.
Ron
A few years before Mr. Mitchel died he told me he ran one in his 3/4 ton Ford pickup with 390 engine with no problems. They should easily take what little abuse a model A engine can give them.
Very stout..they actually speed shift too, the synchro works as fast as you can throw the lever
I have a 26% Mitchel O/D and the Mitchell ****** also in my Roadster. Did that so if I keel over the bride can drive normally to get home. It also is a bit peppier engine than stock and I run 600 X 16 and hyd. brakes. Very responsive and does well on the highways and over the Sierras. Cable shift. 55/60 mph fine, 65 when bored.I have a Mitchell in my 31 S/W town sedan, but with a 4.11 rear end gear. I plan to remove the 4.11 and replace it with a 3.78 ratio.
I've seen several photos of an install with the shift lever. Could those of you who use a cable please post a pic?
