Yes, Please do. I would like to see what the entire unit looks like installed -including the shift mechanism. Thanks.flatmotor40, can you post pictures of your installation? That would be great.
Not a Mitchell overdrive, perhaps it will interest anyone anyway.
Built my from a Volvo 240/740 (Laycook) overdrive. Mounted it in my 40 pickup, I use an electric switch to activate the one seen in the photo.
/40Pickup
Very interesting! Can you give us more details on what you had to do to make it work?
40Pickup
Is that a lockout switch on the shift housing to disable the O/D in reverse?
Thanks
Jim
I, too, would be VERY interested in the details of this conversion - I have all the parts laid out in my garage and am about to try and make one myself.
I must say your conversion looks first class and would appear to be a neat and efficient unit.
Do you have any pictures of: = For the most part, I take photos while on what I do, but unfortunately not this time.
But I shall attempt to come back with some drawings that would clarify.
The adaption of the torque tube to the front of the unit?
The adaption of the driveshaft to the front of the unit?
Mods to the tailshaft housing?
The final driveshaft from the unit to the diff pinion.
Some questions..
Was any resplining involved? = No
The positioning of the unit near the rear end of the torque tube - is there an advantage to this, or could the unit be fitted almost anywhere along the length? = If I understand correctly, you should keep the unsprung weight as low as possible and therefore the O / D when mounted as far forward as possible, while you have to take into account whether there is sufficient space.
Is the lubrication of the unit self contained or shared with the axle? = Self contained (ATF).
I envisage mine being a home brew job with lots of welded up shafts and parts, with the od unit towards the front of the shaft.
To be able to see details of one already made up would be a great advantage.
Thanks in advance, hope you can help.
Merry Christmas.
Mart.
I am thinking about installing a mitchell overdrive unit in a 46 - 48 ford convertible. Does anyone have experience with this, installation tips, pictures of installation , was it worth the effort. Thanks.
Maybe in NZ, but 3.54 in USi think you will find its 3.78 standard ratio for 46fords
Some times I hit the wrong key. Should have been 270 cu. in.[/QUOTE
I thought maybe you meant 270 instead of 370. I built a 284 and first thought man... what in the world did he do to get to 370 ci ?
